WLC + ACS - Full admin rights problem with rogue AP
Dear,
I have a Cisco ACS 4.2 (Windows) and a WLC 2106 5.1.
I would like that the Management User use the TACACS (with the ACS) to authenticate/authorize.
So I have follow the guide:
Cisco Unified Wireless Network TACACS+ Configuration (http://cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a0080851f7c.shtml)
Put in a users group : role1=ALL as describe in the guide.
The problem: With a user from the ACS, I want to contain a rogue AP and I receive a JavaScript Alert Box which display : Authorization Failed. No sufficent privileges.
In the management log:
*Aug 22 14:12:31.103: %WEB-3-USER_NOT_PRIVILEDGED: web.c:462 Form Submission Failed. The user doesn't have the right privileges.
*Aug 22 13:58:15.076: %EMWEB-1-LOGIN_FAILED: ews_auth.c:2092 Login failed. User:glemaireadm. Service-Type is not present or it doesn't allow READ/WRITE permission..
*Aug 22 13:56:46.078: %WEB-3-USER_NOT_PRIVILEDGED: web.c:462 Form Submission Failed. The user doesn't have the right privileges.
What I have missed in the configuration guide ? :o(
Thanks in advance,
rwilkinson Mon, 06/22/2009 - 08:54
I've got the very same issue with version 5.2.178.0. When trying to reclassify an AP, the log reports the following: *Jun 22 17:33:03.839: %WEB-3-USER_NOT_PRIVILEDGED: web.c:465 Form Submission Failed. The user doesn't have the right privileges.
However, if I login as the local admin user, works fine.
Was any solution discovered for this.
Richard Wilkinson
Richard Atkin Wed, 06/24/2009 - 00:34
It sounds like you're missing a permission. Presuming you copied them all out of WCS properly, then there's probably a fault in WCS in that there's no permission/name shown for that particular activity.
Trending Topics - Security & Network
