showrun without breaks
Answered Question
Aug 22nd, 2008
I am trying to figure out how to list a router config in one consecutive display without having to hit a key on the keyboard to continue. I've done it before but have forgotten how.
Correct Answer by Giuseppe Larosa about 8 years 6 months ago
hello,
just type term len 0 at the prompt
then do sh run
hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Mark Yeates Fri, 08/22/2008 - 04:46
Wesley,
If you configure the "length 0" command under line vty or line con 0 it will scroll the entire config without having to hit the space bar.
HTH,
Mark
Correct Answer
Giuseppe Larosa Fri, 08/22/2008 - 05:00
hello,
then do sh run
hope to help
Giuseppe
