VG224 - Analog outbound dialing issue
Aug 22nd, 2008
I am running CCM 4
I have several VG224 services connecting my analog phones to the call manager.
One of my phones has a weird issue
Issue - When you pick up the receiver you hear dial tone. As soon as you press a button, it goes to a fast busy signal.
In the same room, there are 2 other vg224 connections. All 3 phones are configured the same (Partition and CSS).
The other two work fine.
I can call from an outside line and it rings fine and can be answered. I can setup call FNA or FA on its ext and it routes properly (Par and CSS are set correctly).
I cannot figure it out. I want to say it's a wiring problem or that port on the VG might be bad.
I already reset the VG and all the other phones on this VG work. There is an open port I can attempt to move it too.
I was wonder if anyone has seen this issue before? If so, am I going in the right direction thinking it's a physical issue.
Should I repunch the lines and if that fails, move it to the other port.
Overall Rating: 5 (1 ratings)
Rob Huffman Fri, 08/22/2008 - 05:13
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Donald,
It kind of sounds like a bad port if the CSS is the same as the working phones. If you get dial tone and can ring the phone I would think that the wiring is OK. If you are re-punching the line, then try to flip/reverse Tip and Ring just in case the Analog phone you are using is polarity sensitive.
Switching ports is probably the "quick fix" :)
Hope this helps!
Rob
D0nprintup_2 Fri, 08/22/2008 - 06:10
THanks
Thats what I was thinking. I mean I cannot make any more changes to the CCM. We only have 2 partitions and several CSS.
I will try that
Thanks again
Yorick Petey Thu, 09/25/2008 - 05:47
Hi D0nprintup,
We already experienced this kind of issue. Sometimes, you have to launch a reset of the MGCP config from the CallManager side. You have to call Reset from GW config page or by resetting GW's endpoints.
I don't know why it happens. Do you experienced this issue again?
Yorick
D0nprintup_2 Thu, 09/25/2008 - 05:55
Greetings
I forgot to update this. I found out what the problem was.
I logged into the CLI of the VG and after a sh run. I noticed there was a werid setting (Static information) for that port. When I removed the port out of call manager and did a show run again, it was still on the VG. I removed the information from the VG. Then I added it back in via the webpage and did a sh run on the gateway to verify it added it correctly. Now it all works.
Next time I know to check the CLI
Yorick Petey Thu, 09/25/2008 - 06:01
Thank you for your reply.
Your issue is strange indeed... It is not the first time we experience "strange" problems with a VG224 and/or MGCP.
Sometimes the config on VG/GW is not refreshed correctly, sometimes ports are not registered until the next "no mgcp/mgcp", sometimes they are registered to the wrong node not according to the CUCM group order...
We are looking for changing our signaling protocols to MGCP-->SCCP for VG224 and MGCP-->H323, but when the dialing plan is complex, H323 is a pain in the a..!
Good luck :)
Yorick
