Connection limits when static natting a subnet
Aug 22nd, 2008
The device I'm implimenting static NAT on in this instance is an FWSM running 3.1
I want to know, if I static NAT a subnet as opposed to a host, and I want to impliment connection limiting and embryonic connection limiting, will the connection numbers apply to the whole NATted subnet or just individual host IPs within that subnet (I'm hoping for the latter!).
So, for example: static (inside,outside) netmask 1000 20
Does that mean 1000 total connections 20 embryonic for the /24 for or each host within the /24.
Hope that's clear, and thanks for any replies!
Marwan ALshawi Fri, 08/22/2008 - 06:12
interesting question
not sure but for mean it means per line statemnt this limit will apply i mean for the whole subnet in this case
try it make the limit to 3 or 4 amke make more 5 or 6 connections
good luck
