Unity 5 - Unified Messaging - no email notification and VM question.
Aug 22nd, 2008
Hi All,
In Unity with unified Messaging (v5(0)1) - how do I stop email notifications from being sent when a voicemail is sent?
I would assume this is set in COS but I have played around with the settings and can't get it to work.
Second question - how does a subscriber set their voicemail up so they can leave an announcement (e.g. out the office till 5pm - call Jane in the meantime) - but the caller can't leave a message?
Dave
Ginger Dillon Fri, 08/22/2008 - 08:30
  • Blue, 1500 points or more
Hi Dave -
Message Notification is configured on the Subscriber template, which settings are applied when a user is imported/created in Unity. You can use Bulk Edit to change this information for all subscribers. However, a subscriber can re-enable this setting for himself using PCA or TUI conversation. I checked the user guide for 5.x and did not find a setting whereby a user could disable taking a message as the post-greeting option. An administrator can do this for a subscriber by going to the Greeting link in Unity SA and update the "After Greeting" section. Here's the user guide for Unity Assistant - http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/user/guide/assistant/ex/cuugasstepdf.pdf
Ginger
davidme Tue, 08/26/2008 - 13:33
hi Ginger,
Thanks for that though in trying to stop email notification, I have looked and can't find a way of turning this off. If I make any changes - do I then need to restart the Unity service?
Cheers
Dave
Ginger Dillon Thu, 08/28/2008 - 08:32
Hi Dave -
I don't believe there is a global setting available, like in Advanced Settings Tool, to disable message notification for all subscribers. However, to perform message notification, Unity needs one or more (least busy) ports checked for Message Notification. You can check this out in the Unity SA - Ports. If you make a change, just save the changes. It does not require a Unity service to be stopped.
Ginger
