How to configure port mirroring in L2 switch..
Aug 22nd, 2008
Pls provide many links for port mirroring and also whether all the IOS supports port mirroring..
vinothlb1 Sun, 08/24/2008 - 19:43
what command to check whether port mirroring working or not?
Firstly - you shhould be receving alot of traffic on your port niffing software - a clear indication is receving frames destined for the MAC address on the port your are monitoring.
Secondly issue the command "show port monitor fa x/x" at the command line and it will output what ports are being monitored and which ports the info is being sent to.
