VG248 Reboot
Aug 22nd, 2008
Hi, i have four VG248 with 1.3(2) version in the same site. The problem is the VG248 are reseting. For this i checked in the System Status the Up Time param. The fault is random.
The logs are not show the reason for the reset.Pls see the attachment.
drolemc Thu, 08/28/2008 - 10:24
  • Silver, 250 points or more
A hardware power supply failure would also account for similar symptoms.To rule out a hardware fault, look at the Diagnostics -Show environment .
Or reconfigure it and reload VG248.
cristian.munoz Thu, 08/28/2008 - 10:43
Hi Donald
Pls. see the attachment. In this there is a two VG248, with the show environment command.
How know the reason for reset?
