Which command is able to display interfaces' IP address, status and uptime?
Answered Question
Aug 22nd, 2008
Thanks for help.
Correct Answer by branfarm1 about 8 years 9 months ago
The command: show ip interface brief will show the interface name, it's IP address, when the IP was set (boot time, or by config) it's current physical and logical status.
And I don't know about uptime, but the command: show interfaces link will show how long a physical interface has been down.
Overall Rating: 4 (2 ratings)
Correct Answer
branfarm1 Fri, 08/22/2008 - 08:16
  • Bronze, 100 points or more
johnakeating Sat, 08/23/2008 - 08:59
router#show logging
Will show you a history of all interfaces and the UP DOWN status.
you might want to increase the log size to get more keep more information
router#logging buffered 4096 errors
lamav Sat, 08/23/2008 - 14:09
  • Blue, 1500 points or more
John:
You may want to reconsider your advice.
Executing a "sh log" will not give you any interface status and configuration information at all.
Yes, if an interface happened to go down or come back up, there will be an indication in the log. But that is hardly a reasonable way to go about getting interface information.
Victor
AJAZ NAWAZ Sat, 08/23/2008 - 10:53
  • Silver, 250 points or more
take a look at:
show interfaces status
looks quite useful imo.
hth,
Ajaz
