DFM, Critical ; Unresponsive ; Active
Aug 22nd, 2008
  • Bronze, 100 points or more
I'm getting notification mail for the event: Unresponsive (Critical, active and clear)
The problem is that I sometime receive notification for 1 or 2 hit. Is it possible to update the pooling parameter to trigger the event only if the device is unresponsive for x amount of time?
I did some research and I can't find any parameter that I could change.
yanic
Joe Clarke Fri, 08/22/2008 - 10:08
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You can increase the polling cycle, but that wouldn't really accomplish what you want. The ability to configure Notifications to be sent based on duration or number of events in on the roadmap for LMS 3.2 (DFM 3.2).
Anonymous (not verified) Fri, 08/22/2008 - 10:35
Thank you! When can we expect to have version 3.2?
Joe Clarke Fri, 08/22/2008 - 10:39
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
LMS 3.2 is slated for release in Spring 2009.
