How many participants can be on a Conf Call
Answered Question
Aug 22nd, 2008
We have CCM 6.1.1 and use a 7936 Conf Phone. How many participants can be on a conf call? Do you set this by going to:
Service Parameter Configuration-Clusterwide Parameters(Service)-Max Ad Hoc Conf. and change the value here?
Correct Answer by Jaime Valencia about 8 years 6 months ago
this is just like google, try to look: conference users
or some other methods (7936, conference phone, not abbreviations like you did, or simply "conference")
i found other 3 posts regarding this within the 1st page of results
yes, if you plan to use ad hoc conferencing move that parameter
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Jaime Valencia Fri, 08/22/2008 - 12:24
yes, maximum 48 users per conf
number of conferences = 128 / users defined in parameter
this has been asked millions of times before, please try using the search function within NetPro
java
Mojo1 Fri, 08/22/2008 - 12:32
I used your advice and did a search for Conf Phone in Net Pro and this post was the only one pertaining to this subject.
Was I correct in saying you make the change in Max Ad Hoc Conf ??
Correct Answer
Jaime Valencia Fri, 08/22/2008 - 12:46
java
