Pix/Radius and enable mode
Aug 22nd, 2008
Hi all, I am trying to get a pix 6.3 to authenticate telnet users via radius with a Microsoft IAS server. This works well, but Im trying to get it where when they log in, it just dumps them into enable mode, instead of typing in the enable AD credential again. Anyone have any insight on how to do this? Its a IAS configuration thing I know, but not sure what to do with it. Thanks in advance.
Overall Rating: 4.8 (4 ratings)
Premdeep Banga Fri, 08/22/2008 - 13:34
  • Gold, 750 points or more
If you mean on firewall,
Username: alfa
Password: ********
pixfirewall#
Rather then,
Username: alfa
Password: ********
pixfirewall>
pixfirewall>enable
Password: ********
pixfirewall#
The unfortunately, Pix firewall does not have this concept, like IOS devices have.
On IOS you can get the user log directly into enable (Privileged exec) mode by passing attribute,
cisco av-pair as shell:priv-lvl=n or on some IOS only using Service Type as Administrative will do the trick.
Where, n is the privilege level.
AND, there has to be an EXEC authorization command on the IOS device, e.g.,
aaa authorization exec group radius....
Unfortunately, that is not the case for the Pix firewall, they have a different OS.
Prem
Please rate if it helps!
Farrukh Haroon Sun, 08/24/2008 - 11:11
  • Red, 2250 points or more
Even tough the exec authorization feature in the Cisco PIX/ASA is not 'completely' implemented, it does not mean you cannot do things like command authorization on the PIX/ASA. So let us know what exactly do you want to achieve and maybe we could help.
Farrukh
jjoseph01 Sun, 08/24/2008 - 14:42
Hey, thanks. When I telnet into the device, and successfully log in, Id like it to dump me directly into enable mode. routername# instead of routername>
Premdeep Banga Mon, 08/25/2008 - 03:41
Unfortunately, this kind of functionality is not included in the PIX/ASA OS as of now.
Prem
nobleton3366 Mon, 08/25/2008 - 07:25
Do you know if there is a plan to support this in any later versions? In my work enviroment shared passwords are not allowed. Thanks.
Premdeep Banga Mon, 08/25/2008 - 07:31
You might want to contact your accounts team for the same.
If sharing of password is not allowed, then you can enable, enable password authentication on firewall, i.e.
aaa authentication enable console LOCAL
And on the ACS server, under user's profile, make sure that enable password is selected as the user's account password against the respective database.
Prem
nobleton3366 Tue, 08/26/2008 - 05:17
Thanks works great thanks. One more question...
On my IOS equipment, I am able to make it check the LOCAL db first then radius rather than radius first. Is there a way to do it this way on the ASA?
Farrukh Haroon Tue, 08/26/2008 - 05:21
Yes the AAA method list functionality is identical on both platforms. The IOS 'local-case' is the 'LOCAL' on ASA.
Farrukh
Premdeep Banga Tue, 08/26/2008 - 05:29
I think on your IOS this is how you are doing the authentication,
aaa authentication login default local group radius...
Local first and then Radius, right ?
If I understand you situation correctly, then that functionality/behavior is not how ASA/PIX firewall works.
If you specify LOCAL, then there is no other method available, i.e.,
aaa authentication telnet console LOCAL
But, you can specify the fallback as LOCAL in the event your Radius/Tacacs server is not available,
Prem
nobleton3366 Tue, 08/26/2008 - 06:44
I was afraid of that, but we can make it work. Thanks again.
jjoseph01 Thu, 08/28/2008 - 07:33
I forgot to rate this, so came back to do so. Thanks for all your help.
