Farrukh Haroon Fri, 08/22/2008 - 21:51
  • Red, 2250 points or more
You can enter the "failover reload-standby" command on the active firewall's CLI to reload the standby unit. If this is what you are looking for?
Farrukh
sateeshk10 Sat, 08/23/2008 - 06:50
Means i neeed to reboot my secondary firewall from primary only... i cant reboot the sec FW from console right???
When i tried to reboot the FW from secondary its not taking..
with abv mentioned command we can achive the same right?
sateesh
Farrukh Haroon Sat, 08/23/2008 - 08:15
You can use this command OR logon directly to the standby device and reboot it. (Unless something has changed in newer versions) I remember rebooting the standby (or secondary unit) many times via directly logging into it.
The above command helps you in a way that you don't need to login to the secondary unit.
Farrukh
