A script question,Help!
Aug 22nd, 2008
I want to set the CRS AA script support for incoming users to enter the internal extension (for example, 801), if the extension is not known the numbers type 0 to be directly switchboard, I how to achieve?
Thanks! !
Jonathan Schulenberg Fri, 08/22/2008 - 19:38
  • Cisco Designated VIP,
    2017 IP Telephony
You can use the Call Redirect step. Within the Invalid, Busy, or unsuccessful branches you can add another Call Redirect to the switchboard DN.
quanmazjl Sat, 08/23/2008 - 08:33
I would like to set up how I can identify the type the numbers 0 and 801.
shrutid22 Mon, 08/25/2008 - 00:09
use the get digit string step
store those digits in string variable
redirect the call to that string variable
quanmazjl Mon, 08/25/2008 - 18:24
Thanks!
get digit string
Filter:
input Length: ?
Terminating Digit:none
I need to set up how to make access to the variables that can be a 0 is also three of 801?
I do not want to have terminating Digit.
In setting the input Length of three, how to identify the user input is one of the 0?
honniesr Tue, 08/26/2008 - 10:48
sounds like he was talking about three different input strings. One for each character. If the first character is a 0, then you are done and you goto the transfer to operator function. If the first character is an 8, you store that 8 in a variable and go to the next get digit function (just getting ONE character). Store that concatenated in the same variable (i.e. number=number+getdigit)
Robert
