what is the heart beat link down between 2 ASA?
Answered Question
Aug 23rd, 2008
we have 2 firewall connect via dedicated link and ruuning A/S, my uqestion is, what is heartbeat link down, doea that cause the 2 ASA all active? in that case, our switch will send traffic to 2 firewall?
Correct Answer by Farrukh Haroon about 8 years 11 months ago
Under normal operation if it goes down, no the situation you describe will not happen "our switch will send traffic to 2 firewall". However if they reboot, both units will become active. Have a look at this table:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00807dac5f.shtml#actio
Please rate if helpful.
Farrukh
Overall Rating: 5 (1 ratings)
Correct Answer
Farrukh Haroon Sat, 08/23/2008 - 08:25
  • Red, 2250 points or more
Farrukh
GRAEME DANIELSON Mon, 08/25/2008 - 01:27
For best results I always put a switch between the failover interfaces. If you use a crossover Ethernet cable then one unit going down also takes down the partner unit's failover interface. This can confuse the failover process and give you strange results.
