Problems in reverse route injection
Aug 23rd, 2008
We have a setup where the hub router is connected to different spoke routers.We are running eigrp, the back connectivity is through vpn tunnels. When the primary link comes up after a failure then the reverse routes are not getting deleted.we have to manually clear the sa .tried using reverse router remote peer ip address in the crypto map without sucess.I am attaching the show techsupport and debug outputs of the hub router and a sample spoke. Pl suggest
Farrukh Haroon Sat, 08/23/2008 - 04:11
  • Red, 2250 points or more
Try to enable keepalives with same values on ALL sites:
crypto isakmp keepalive 20 3
Farrukh
