Glad your upgrade went as plan.. although you should still be aware and have an eye for overall performance I would not worry to much about high memory unless u start experiencing issues. High memory have been reported even on ASA5500 running various code versions to be normal, pay close attention on overall PIX traffic. For instance high CPU would be something to worry about..
The 128MB RAM is Cisco's recomended memory for upgrading from 6.x to 7.x or above, by your description of 128MB I can say you have 515E PIXes and I believe that is the maximun memory it can hold 64 per bank for UR/FO pair.
Keep this link handy for future
Monitoring PIX/ASA performance
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a008009491c.shtml
Rgds
Jorge
Jorge Rodriguez
