aaa do1x configured locally without server
Aug 23rd, 2008
Hello people, I am having some problems test AAA authenitication.
Here are the commands I have on the switch.
username cisco password cisco
aa new-model
aaa authentication dot1x default-local
dot1x system-auth-control
int fa 0/3
switchport host
switchport access vlan 3
dot1x port-control
after this configuration my port goes yellow obviously cos I have not entered the password. I tried to enable authentication features on the local area connection properties box on the PC but it does not prompt me to enter password after all my attempts Please does anyone have a solution for me. Thanks
Overall Rating: 3 (1 ratings)
Premdeep Banga Sat, 08/23/2008 - 12:16
is the command
aaa authentication dot1x default local,
Use the first one.
And if you are using Window PC, then by default its configured for smart card/EAP-TLS authentication, change it to MD5 and try.
Please rate if it helps!
Sarg . Sat, 08/23/2008 - 13:22
Thanks i will try this when i get back to school after bank holiday monday. Thanks
I'll be sure to give u feed backs
Sarg . Tue, 08/26/2008 - 14:10
Thanks so much pal. Everything when rather well. The PC now prompts me for user name password. I noted that it also asked me for domain-name.
I was not too sure about the importance of this so i just went into the switch anyway added
(config)# ip domain-name cisco
anyway, once i was through doing that i went to the PC and add the login and password but the PC reports back that it failed to authenticate.
I then went back into the switch and add
(config )# Username cisco password cisco level 15
and still the PC keeps informing me that it can not authenticate with a 'failed to authenticate' report was then wondering if my PC actually supports Extensible Authentication Protocol
could this be the problem? if so , how can i cross check this?
cheers for you time
Premdeep Banga Tue, 08/26/2008 - 15:00
to be frank, what you are doing, no one does that i.e. using routers/switch local database. I am not sure, I might have to look it up. But I dont think router/switch local database supports EAP-MD5. As far as domain goes, leave it blank when filling that information for authentication.
I would suggest if you are testing, use an ACS for Windows trial version, as a Radius server.
Sarg . Tue, 08/26/2008 - 15:23
Yeah, i can understand. I am a student.I am just trying some hands-on-labs
cheer for the effort
Premdeep Banga Tue, 08/26/2008 - 15:29
you must have a valid profile. If you dont, please Register, you should be able to download the trial.
