espereir Mon, 08/25/2008 - 07:45
  • Silver, 250 points or more
Hello Nelson,
Could you please tell us how MP is integrated with CUCM? are you using a trunk or a gateway?
Anyhow, check the CSS of the integration and make sure that it has the partition that contains the route patterns, you could use the same CSS that you have on your phone.
In addition, if the problem persist after checking the CSS, could you please send us a test trace?
Thanks!
nelson-rick Mon, 08/25/2008 - 09:43
Is it integrated via a gateway. Everything is using the CSS right now. Should I change this?
nelson-rick Mon, 08/25/2008 - 10:21
Configured Partition and CSS no luck. I am getting H323:Error while getting PSTN code:-1.
As I said before incoming calls are working fine.
Is there something I need to add to the Audio Server to tell it where to send outbound calls?
espereir Mon, 08/25/2008 - 11:02
Nelson,
The CSS on the GW will allow calls from the GW (MP) to the CCM. MP Express should hit dial-peer that you have on the Integration GW and then, the RP that you have on CCM.
Please send us a trace file and a debug from the GW for us to check what is going on.
Thanks!
nelson-rick Wed, 08/27/2008 - 03:59
Redid the gateways and rebooted the CallManager everything is good to go.
