08-23-2008 03:43 PM - edited 03-15-2019 12:48 PM
I'm attempting to set up a call between two IP phones across a WAN. I currently have a translation pattern set up for the central site phone to call the branch site phone and it works fine.
The problem is that if the WAN circuit goes down, the call goes to voice mail. I need the call to fallback to the PSTN through the central site gateway.
If I remove the translation pattern and use a route pattern and dial-peer on the gateway, the remote phone will ring, but the call will not connect when answered, the central site phone just keeps ringing.
Is there a better way to do this?
I'm using g711ulaw in and between all of the regions.
Central Site w/srst --> Branch Site w/srst
This is the dial-peer on the central router
dial-peer voice 102 voip ****Remote phone rings but does not connect.
description *On-Net calling to IP phones*
translate-outgoing called xxx *** converts to 7-digit
preference 1
destination-pattern 8xxxxxxxxxx
voice-class codec 1
voice-class h323 1
session target ipv4:10.10.1.1 ***CCM server or to Branch gateway same result
dtmf-relay h245-alphanumeric
no vad
Any ideas are appreciated.
08-23-2008 06:22 PM
can u post both sides pots dial-peers
because u said ur problem with pstn calls
08-25-2008 04:50 AM
Meant to do that earlier.
Tail-end hop off works fine from the central site out through the branch gateway as well.
This is the branch site dial-peer for voip and pstn
dial-peer voice 100 voip
description **Primary CCM Sub2**
translation-profile incoming block
preference 1
destination-pattern 55511.. ***Local IP Phone prefix
progress_ind setup enable 3
progress_ind progress enable 8
voice-class codec 1
voice-class h323 1
session target ipv4:10.10.1.1 ***Central site CCM server
dtmf-relay cisco-rtp h245-signal h245-alphanumeric
no vad
08-26-2008 02:20 AM
When the WAN is down it goes to VM, is the Call Forward not Registered pointing to VM ? CUCM has no knowledge of the phone when the WAN is down so becomes unregistered so technically you could use this manor to forward to the Telco DDI number however the issue you have is that CCM also uses this for logged off handsets if you use Mobility ? if you do not use Mobility then no problem however be aware disconnecting the phone has the same effect. Another option is to use the AAR in that when the WAN is down , set the AAR bandwidth to 1K so to invoke AAR - overflow to Telco
08-26-2008 08:25 AM
When the WAN goes down it does point the number to VM. I'm not using mobility on any of the phones.
I currently have the central site callers dial the 11 digits for long distance to the branch site. They use a dial-peer on the central router to the PSTN. I can create a preference 1 voip dial-peer before the SRST pots dial-peer to redirect it across the WAN. The problem is that the branch phone will ring, but the call will not connect when it's answered. The central site phone will continue to hear ringing.
