PIX OS 8.0 VPN, Static Nat, PAT configuration help
I have a PIX 515E, I need to do static NAT between my exchange server and the public IP which is seating in my inside network, I need a VPN to access the citrix server and I need a PAT with the outside interface of the PIX.
Below is my network layout, I tried to do the configuration but both the configurations are not working.
Kindly help suggest some sample configurations; I will be rating the suggestions.
Farrukh Haroon Sun, 08/24/2008 - 06:30
Regarding the STATIC outside >> inside natting have a look at this link:
This document is for mail, the CITRIX configuration is the same, just need to know the ports used.
For dynamic NAT/PAT you just need two lines:
nat (inside) 1
global (outside) 1 interface
