asa 5510 how to upgrade security plus license
Aug 24th, 2008
dear techies
I have 2 asa 5510 firewall and
want upgrade to security plus image to support HA and failover .
I know I can get license from ciso partner for the price ,
but I dont know the procdure for the upgrade
Plz shower your inputs
Frederick Reimer Sun, 08/24/2008 - 05:43
When you order the new license you will get a PAK (Product Authorization Key). Go to www.cisco.com/go/license and enter in your PAK. You'll then have your activation-key that you can install on the ASA.
samerhabbouch Sun, 08/24/2008 - 12:37
dear freimer
thanks for your vital information
my best regards for you
