Install CCM 4.0(2) whitout hardware detection
Aug 24th, 2008
Hi Tac
I need install CCM 4.0(2) in a 7835-H2 server, but I don't have the hardware detection for this server, have only the CCM 4.0(2) software.
how to can install the S.O. without the HD cd's?
w
Who software I need for install the machine manually
testeven Mon, 08/25/2008 - 14:45
  • Cisco Employee,
Hi!
You will need the Hardware Detection CD. It's part of the 4.X installation process as CCM works with a customized OS system. You can't install any OS you get from Microsoft.
If you don't have the CD you can try the following procedure:
Go to the Product Upgrade Tool (PUT)
http://tools.cisco.com/gct/Upgrade/jsp/index.jsp
or
www.cisco.com/upgrade
(registered customers only). You'll be required to enter your Cisco Software Application Support Plus Upgrades (SASU) contract
number and request the CD/CD set.
If you have any problems finding the part numbers that you need or with the order placing please send an email to [email protected]
Just send them an email requesting the SW CDs that you need, adding your contract number and the shipping address.
If you have a CD mis-shipment problem, then the Customer Service department should be involved. They can be contacted at
[email protected].
For more information you can call Customer Service at 1-800-553-6387
Finally I'm sending you all the detailed info about the procedures on CDs requests, for future needs:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_qanda_item09186a00802262ed.shtml
NOTE: Cisco TAC does not provide installation media.
But, the issue here is the CCM version, as it's quite old. See the End of sale announcement:
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps556/ps5453/prod_end-of-life_notice0900aecd806f4181.html
I would ask for a CCM 4.2 instead.
Tere.
