Tutorial to set up an Easy VPN Server and DMVPN Hub on 1 router
Aug 24th, 2008
I've successfully deployed this and wrote a tutorial about it, given the number of questions that I found floating around this subject on the web I figured some of you might be interested. I've also pointed out several issues that can arise while implementing such as NAT issues with directly attached hosts to the DMVPN Hub and an error in the Cisco examples that are available. You can find it here: http://edge-technology.blogspot.com/2008/08/easyvpn-server-and-dmvpn-hub-on-1-cisco.html
Overall Rating: 5 (1 ratings)
mefkeys Mon, 08/25/2008 - 07:12
Yes, I also referred to it in my tutorial. However as some of the configurations as mode transport for the transform-set and NAT can cause problems I decided to write my own tutorial.
Farrukh Haroon Mon, 08/25/2008 - 10:52
Oops sorry I did not read your initial post carefully enough. Thanks for sharing your tutorial on NETPRO.
