Warning message
Routing
Aug 24th, 2008
s1(BGP) s1 (eirgp) s0(eirgp) e0
---->>RouterA<<---------------->>RouterB<<----------
I connected one interface BGP and another interface is eirgp,
am unable to ping the router Ethernet from routerA after configuring the redistribute bgp 65003
Router A
interface Loopback0
ip address 10.1.1.2 255.255.255.0
interface FastEthernet0
ip address 10.254.9.40 255.255.255.0
speed auto
interface Serial0
description PE30-AIRTEL-NOC [192.168.30.1/24]
ip address 192.168.30.2 255.255.255.0
encapsulation frame-relay
frame-relay interface-dlci 100
frame-relay lmi-type ansi
interface Serial1
description CE50-AIRTEL-HYD [10.20.30.2/29] [This serial connected to CE50-AIRTEL-HYD setial0/0/0]
ip address 10.20.30.1 255.255.255.248
interface Serial2
description CE60-AIRTEL-KOLKATTA [172.26.8.2/30]
ip address 172.26.8.1 255.255.255.252
router eigrp 100
network 10.20.30.0 0.0.0.7
auto-summary
router bgp 65003
no synchronization
bgp log-neighbor-changes
network 10.1.1.0 mask 255.255.255.0
network 10.254.9.0 mask 255.255.255.0
redistribute eigrp 100
neighbor 192.168.30.1 remote-as 65003
auto-summary
ROUTER B
interface FastEthernet0/0
ip address 192.168.100.1 255.255.255.0
speed auto
full-duplex
no mop enabled
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface Serial0/0/0
description PE40-AIRTEL-NOC [10.20.30.2/29] [This serial connected to PE40-AIRTEL-NOC serial 1]
ip address 10.20.30.2 255.255.255.248
router eigrp 100
redistribute connected
network 192.168.100.0
auto-summary
Jon Marshall Sun, 08/24/2008 - 20:50
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
It's not entirely clear what you are trying to ping and from where but one obvious issue with the config on router A is that under your eigrp configuation you need to supply metric values when you redistribute BGP routes into EIGRP eg.
router eigrp 100
redistribute bgp 65003 metric 10000 1 255 10 1500
Can you update config and retest.
Jon
