ASA 5505 with llinksys
Aug 24th, 2008
I have cisco ASA 5505 at my end n I am planning to get a linksys( entry level ipsec support router). Is it possible to create a site to site ipsec tunnel between both cisco asa n linksys router ? pls. suggest me any entry level linksys router that can be used for this purpose.
dhananjoy chowdhury Mon, 08/25/2008 - 08:05
Yes you can.
Get a Linksys BEFSR41 VPN Router.
For configuration on ASA ,
For configuration on the Linksys router
The options on the VPN page may be a bit different depending on the firmware.
Make sure you have the same pre-shared key , Encryption, Authentication settings on both sides.
Also, on the Linksys box,
Under Remote Secure Group > select Subnet and then provide the LAN IP subnet that is behind the ASA.
Under Remote Security Gateway > select IP address and provide Public IP of the ASA box.
PFS > keep it disabled.
Hope this helps.
