FWSM sending Logs to SMTP server
Aug 25th, 2008
We have a requirement where the FWSM has to send logs messages to the exchange server (located on a directly connected DMZ).Will the following configurations be enough.
logging on
logging from [email protected]
logging recipient-address [email protected]
smtp-server 172.18.0.101
I am assuming that the id [email protected] has to be created on the smtp sever. Is any other configuration required in fwsm?
Thanks in advance
Sonu.
Overall Rating: 5 (1 ratings)
dhananjoy chowdhury Mon, 08/25/2008 - 08:14
  • Silver, 250 points or more
On the FWSm,
give the command "logging mail "
setting a log sev-level is recommended, otherwise the mail server will be flooded.
"logging mail 3" should be OK, sending only emergency, critical, alert and error logs only.
Also on the SMTP server, allow the FWSM IP to send mails.
