PPPoE And 2811 Router - Bridged mode
Aug 25th, 2008
Hi, I am trying to get a cellular router working in bridged mode so I can set up a VPN tunnel from a Cisco router. I am not able to get the PPPoE connection established and was hoping someone could help. My config is: Internet-->Cellular780seu-->(FA0/0)2821(FA0/1)
vpdn enable
interface FastEthernet0/0
no ip address
no ip mroute-cache
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
no cdp enable
interface FastEthernet0/1
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface Dialer1
description Logical ADSL Interface
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap
ppp ipcp route default
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
ip http server
no ip http secure-server
ip nat inside source list 10 interface Dialer1 overload
access-list 10 permit 192.168.1.0 0.0.0.255
dialer-list 1 protocol ip permit
no cdp run
This connection does not require a username & password, and works when I set up a miniport dial using WinXP. Can someone please assist?
Thanks!
Giuseppe Larosa Mon, 08/25/2008 - 01:18
Hello Mattie,
then remove ppp authentication pap
inside dialer interface config
you can use debug ppp neg and debug ppp auth to see what happens
Hope to help
Giuseppe
mattiep00 Mon, 08/25/2008 - 01:51
Thanks for the quick response. I have removed the auth, but nothing is happening after shutting/nos hutting the interface. I have the following ints:
FA0/0 unassigned UP UP
FA0/1 192.168.1.1 UP UP
NVI0 unassigned UP UP
Virtual-Access1 UP UP
Virtual-Access2 DOWN DOWN
DAILER1 unassigned UP UP
Debugs are not showing anything. I have tried pinging from the 192.168.1.1 interface to google's IP address with no activity...
Giuseppe Larosa Mon, 08/25/2008 - 04:19
Hello Matt,
now we need to understand when the PPPoE session fails:
use
http://www.cisco.com/en/US/docs/ios/12_2t/12_2t2/feature/guide/ftpppoec_support_TSD_Island_of_Content_Chapter.html#wp1051946
use
show pppoe session
debug pppoe {data | errors | events | packets}
note: depending on IOS release config of PPPoE release requires or doesn't require the vpdn configuration.
If you need vpdn :
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
after release 12.2(13)T config changes
Hope to help
Giuseppe
mattiep00 Mon, 08/25/2008 - 20:34
Ok, getting a bit closer. When i now do a debug ppp negotiation i get the attached. Interfaces go up, then come back down. Any ideas?
Giuseppe Larosa Mon, 08/25/2008 - 22:29
Hello Matt,
I see that you still have some authentication issue:
in the first log file I see:
*Aug 25 22:38:40.355: Vi2 PPP: No authorization without authentication
*Aug 25 22:38:40.355: Vi2 PPP: Phase is AUTHENTICATING, by the peer
*Aug 25 22:38:40.363: Vi2 CHAP: I CHALLENGE id 1 len 35 from "UMTS_CHAP_SRVR"
*Aug 25 22:38:40.363: Vi2 CHAP: Unable to authenticate for peer
*Aug 25 22:38:40.363: Vi2 PPP: Sending Acct Event[Down] id[4A]
*Aug 25 22:38:40.363: Vi2 PPP: Phase is TERMINATING
your router is receveing a CHAP challenge from the PPP peer UMTS_CHAP_SRVR
in the second log file I see a change: now there is a mismatch on the authentication protocol between CHAP :
Aug 26 04:03:49.106: Vi2 LCP: AuthProto CHAP (0x0305C22305)
and MS-CHAP (that is different)
it looks like your router is proposing MS-CHAP and the peer rejects it
Try to use CHAP on your router.
*Aug 26 04:03:49.142: Vi2 LCP: O CONFREQ [ACKsent] id 5 len 15
*Aug 26 04:03:49.142: Vi2 LCP: AuthProto MS-CHAP (0x0305C22380)
*Aug 26 04:03:49.142: Vi2 LCP: MagicNumber 0x1CB58CB2 (0x05061CB58CB2)
*Aug 26 04:03:49.158: Vi2 LCP: I CONFREJ [ACKsent] id 5 len 9
*Aug 26 04:03:49.158: Vi2 LCP: AuthProto MS-CHAP (0x0305C22380)
Your router sends a Config request with auth proto = MS-CHAP the other side answers with a config reject for this protocol.
Try to use CHAP on the router instead of MS-CHAP.
Hope to help
Giuseppe
