Form BGP neighbor
Aug 25th, 2008
Hi all,
Any one if if i can use virtual to form bgp neighbor ?
interface Port-channel1
ip address 192.168.1.2 255.255.255.192
standby 1 ip 192.168.1.1
router bgp xyz
no synchronization
bgp router-id 192.168.1.1
Calin Chiorean Mon, 08/25/2008 - 03:31
  • Silver, 250 points or more
Hi there!
I believe that it is possible.
Under the router bgp x you have to specify:
neighbor "peer_IP_virtual_intf" remote-as "x"
neighbor "peer_IP_virtual_intf" update-source "local_IP_virtual_intf"
of course you have to have some dynamic routing protocol or static routing to reach "peer_IP_virtual_intf"
Good luck!
Cheers,
Calin
Giuseppe Larosa Mon, 08/25/2008 - 04:43
  • Hall of Fame,
    Founding Member
Hello Jack,
for BGP the better solution is to use loopback addresses as BGP endpoints.
using an HSRP VIP could be possible but when HSRP changes state the session has to be negotiated again.
Two established peers exchange only BGP keepalives: when HSRP changes states the new Active router will receive BGP keepalives for a session that it is trying to negotiate.
So it can take some time: BGP is has a neighbor state machine is not plug and play.
I think it is better to have two BGP sessions terminated on loopbacks.
Hope to help
Giuseppe
