ASA with Dual Site-Site VPN
Aug 25th, 2008
Can I terminate two ISP connection with two separate Site-site VPN from each service provider one site-site VPN for back up between two locations provided with one ASA box at each locations.
Overall Rating: 4 (1 ratings)
Marwan ALshawi Mon, 08/25/2008 - 05:29
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
u can
but u need to make the proper rouing
for example
route outside >>>ISP1
route outside2 >>ISP2 higher metric
then
make one crypto map aply to each interface
baseed on ur routing
when the first ISP down the second route map will be used so the site to tsite will use the second interface thorugh the ISP2
good luck
please, if helpful Rate
rohandast Mon, 08/25/2008 - 22:17
Thanks for the reply. But there is some other issue. The client wants to teminate both site to site VPN for the same public instead of routing to different IP in the destination. I think configuration is an issue in this case, Let me know your thoughts Would be helpful to resolve the issue.
Marwan ALshawi Tue, 08/26/2008 - 00:31
the problem is ASA dose not support loadbalanceing
in ur case u need a virtual IP like with HSRP to make it one destination
but with ASA limited feature in this case
if u can get routers infront of the ASA might u can get around it !!
and based on the suggestion i have given to u prevously in case of one ISP fauler the client need to reestablition the connection!!
