SSL VPN
Aug 25th, 2008
I m not able to configure the SSL VPN on cisco vpn concentrator with verion 4.x. I am not able to access the vpn concentrator via public interface. dont know what i m missing. I have enable the http/https access on public interface but still not able to do this. I even regenerate the certificate but still the problem is there.
Pleaes help me out.
dhananjoy chowdhury Mon, 08/25/2008 - 07:57
  • Silver, 250 points or more
Check the following
1. Are you able to ping Public interface IP >. if not, check for the Default GW / Routes.
2. ReCheck whether you have enabled the HTTP/HTTPS management on the Interface2 (Public)
3. Did you enable WebVPN under the Interface 2 (Public)
wasiimcisco Mon, 08/25/2008 - 08:36
Everything checked, Concentrator is alive and so many tunnels are working fine.
HTTP/HTTPS checked i have so mnay times uncheck, disable enable interface, even restart the concentrator webVPN checked
but not working anything.
It was fine few weeks ago, but i dont know what i did wrong now it is not working.
dhananjoy chowdhury Tue, 08/26/2008 - 07:02
Did you change the RULES on the default Filter applied on Public interface ?
