Region config
Aug 25th, 2008
I have a scenario where in CCM 2 regions are configured. Region A has defined G.711 as the codec to be used when a call is made to region B over WAN. Problem is, Region B has defined G.729 as the codec while calling region A.
What will be the result when 2 regions try to call each other?
Overall Rating: 5 (1 ratings)
jbarcena Mon, 08/25/2008 - 06:37
  • Red, 2250 points or more
Mmmmhh, are you sure? because you should have the same codec on both, in fact if you change it in one it should automatically change it on the other one.
