High WAN RTT and OSPF
Aug 25th, 2008
Are there any special considerations when designing a WAN with OSPF that includes nodes that have RTT's around 200-300ms? Will that amount of delay cause issues?
--Brandon
branfarm1 Mon, 08/25/2008 - 08:58
In this case the high RTT is due to distance, New York - Hong Kong. I'm designing a new network with an OSPF core across a VPLS mesh network. I'll have sites in London, Hong Kong, and New York. Do you think this will cause any issues?
Danilo Dy Mon, 08/25/2008 - 18:37
I usually use BGP for long distance, and use OSPF for short distance.
branfarm1 Tue, 08/26/2008 - 05:57
Since I have no working knowledge of BGP, I'm very very hesitant to try and implement that. I'm just curious if 200-300ms of latency between the two most distant nodes will cause any problems with OSPF.
Thanks again,
--Brandon
