Add Area Code Call Manager
Answered Question
Aug 25th, 2008
I was wondering if it is possible to have Call Manager add the area code to a call? We have a branch office that has it own local gateway. When someone places a call from the branch they only have to dial 7 digits for the local call. If possible I would like to reroute calls out of our HQ if their local pri is down. During the time that the local pri is down is it possible to have call manager add the local area code for phones in that branch when their calls are being routed out the HQ pri.
Correct Answer by Jaime Valencia about 8 years 11 months ago
all calls with that route list
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Jaime Valencia Mon, 08/25/2008 - 09:09
  • Cisco Employee,
  • Hall of Fame,
    2011
yes, configure the prefix under the route list for that route pattern
java
wbarren Mon, 08/25/2008 - 09:14
Will that add the are code on all calls though?
Correct Answer
Jaime Valencia Mon, 08/25/2008 - 09:16
  • Cisco Employee,
  • Hall of Fame,
    2011
java
