CAS behind firewall issue
Aug 25th, 2008
I have a a setup with one CAM, one CAS and a firewall between them. There is also NAT in place.
I changed the requiered things like in the configuration guide.
After the changes, I'm able to connect the CAM with the CAS. But after the a reboot of the CAS the connection is broken and cannot be "repaired" because the CAM tries to connect to the original IP and not to the NAT IP which it was connected to earlier. I can only "repair" the connection when I delete the CAS on the CAM an reinitiate the connection.
Any ideas?
regards Dirk
sadbulali Fri, 08/29/2008 - 08:30
  • Bronze, 100 points or more
When using NAT on the trusted (eth0) side of the CAS, the CAS remains manageable by the CAM by passing the NATed service IP address to the CAM using the "autoconnect" feature.
fouzi Thu, 12/11/2008 - 04:16
hi
"When using NAT on the trusted (eth0) side of the CAS, the CAS remains manageable by the CAM by passing the NATed service IP address to the CAM using the "autoconnect" feature."
how to activate "autoconnect" feature
best regards
