Reliable Static Routing Backup Using Object Tracking
Aug 25th, 2008
To configure a reliable static backup route between two routers we control.
Both RTR IOS are same at 12.4.x
1. The wirless is the primary link (Uses FastEth0/x) on both RTR 1 and 2
2. The T1 is secondary (Uses Serial0/0/0:x) on both RTR 1 and 2
3. Wb 1 (wireless bridge) is the icmp object for RTR2
4. Wb 2 (wireless bridge) is the icmp object for RTR1
We have not been successful in getting this to work.
RTR 2 Config (pulled from the above document and modified for our environment).
ip sla monitor 1
type echo protocol ipIcmpEcho x.x.x.x (WB1)
timeout 1000
threshold 2
frequency 3
ip sla monitor schedule 1 life forever start-time now
track 123 rtr 1 reachability
Interface FastEthernet0/1
description Connected to Wireless Bridge 2
ip address x.x.x.x x.x.x.x
no ip route-cache cef
no ip route-cache
duplex auto
speed auto
interface Serial0/0/0:1
description T1
no ip route-cache
ip local policy route-map MY-LOCAL-POLICY
ip route x.x.x.x x.x.x.x FastEthernet0/1 track 123 - Route out to RTR1 VLANx subnet
ip route x.x.x.x x.x.x.x x.x.x.x - Route out to internet
ip route x.x.x.x x.x.x.x Serial0/0/0:1 254 - Desired Backup Route to RTR VLANx subnet
ip route x.x.x.x x.x.x.x Serial0/0/0:1 254 - Desired Backup Route to RTR VLANx Subnet
ip route x.x.x.x x.x.x.x Serial0/0/0:1 254 - Desired Backup Route to RTR VLANs Subnet
access-list 101 permit icmp any host x.x.x.x echo (WB1)
route-map MY-LOCAL-POLICY permit 10
match ip address 101
*1 set ip next-hop x.x.x.x
*2 set interface Null0
*1 According to the document referenced above you should set this to the IP of the next hop for the primary/tracked route which in this case should be the
FastEth0/1 interface on RTR1
*2 Whenever I set this command I get this WARNING: %Warning:Use P2P interface for routemap
set interface clause
It appears to take the command anyway.
ip sla monitor 1
type echo protocol ipIcmpEcho x.x.x.x (WB2)
timeout 1000
threshold 2
frequency 3
description Connected to Wireless Bridge 1
no ip route-cache
duplex auto
speed auto
description T1
no ip route-cache
ip route x.x.x.x x.x.x.x FastEthernet0/1 track 123 - All Traffic to RTR 2
ip route x.x.x.x x.x.x.x Serial0/0/0:1 254 - Desired Backup Route to RTR 2
access-list 101 permit icmp any host x.x.x.x echo (WB2)
If I am understanding how this should work you would need the route-map policy next-hop to be the next hop of your backup route and not the next-hop of the
primary route. In addition I am not sure why you need the set interface null0. It does not appear to be supported in the way I am trying to use.
Any help/clarification here is greatly appreciated.
dwesterhouse Mon, 08/25/2008 - 13:12
Some addtional information when performa a test failure on the RTR1 tracked object
RTR2#sh track
Track 123
Response Time Reporter 1 reachability
Reachability is Down
18 changes, last change 00:13:35
Latest operation return code: Timeout
Tracked by:
STATIC-IP-ROUTING 0
FFSRouter#sh ip route track
ip route x.x.x.x 255.255.255.0 FastEthernet0/1 track 123 state is [down]
Gateway of last resort is x.x.x.x to network 0.0.0.0
S x.x.x.x/24 is directly connected, Serial0/0/0:1 - This is the correct backup route
x.x.x.x/16 is variably subnetted, 2 subnets, 2 masks
C x.x.x.x/29 is directly connected, FastEthernet0/1 - Primary
C x.x.x.x/30 is directly connected, Serial0/0/0:1 - Secondary
S* 0.0.0.0/0 [1/0] via x.x.x.x
RTR1#sh track
Track 123
Tracked by:
STATIC-IP-ROUTING 0
The routing table also showed the correct entries while the primary link (wireless) was in a fail test (we simply powered down the bridge), but then I could not ping nor get other traffic to flow between the routers.
According to what I am seeing in the sh track, sh ip route track and sh ip route commands both routers should be using the serial0/0/0:1 (T1) line to pass all traffic between the routers and it should work!!! This driving me crazy... Please advise... Am I going crazy? Is there an easier way to do this?
