Self Signed Certificate For ACS
Aug 25th, 2008
I am running version 4.1 of the ACS appliance and was wondering if anyone knew of a way to get around the limitation of the 1 year self signed certificate? We had no external CA infrastructure.
Is there a way of creating the CA certificate on an external (temporary) Windows/Linux box and then importing this onto the ACS for use?
gng4life Mon, 09/01/2008 - 12:22
This will be on an isolated network and will only authenticate/authorize a few switches and routers. No MS/Linux on this LAN will use ACS, you still have to create the CER? I could only find where that is needed for EAP, PEAP, HTTPS, Positure Validation, etc. I'm just trying to get the basics working so I can get this started, tested, then move to other things. If you think this is still needed, I'll create the self-signed one but I'm not sure if it will do any good. Thanks for the reply.
gng4life Tue, 09/02/2008 - 00:52
My apologies, I replied to the wrong conversation. I am sorry for the confusion.
