Exceptions
hi, i wish know about this output?
Error Msg:
SysAD Parity Error Exception occurred
Mistral:
int_stat: 0000000000000000
int_src_stat: 0000000000000000
int_src_stat10: 0000000000000000
EPC: 20AE0D6C
Traceback:
20AEA1D0
20AEA1D0
20AC2A94
20AD6464
20CDC3A4
20CDC354
Stack content:
sp+00: 00000023 0000008C A1907668 28908D24
sp+10: 28EC3C90 00D20101 00000001 00000000
sp+20: 00000000 00000000 00000000 00000000
sp+30: 00000000 00000000 3FF72150 20AD6464
sp+40: 20AD5CC8 00000000 00000000 3FF72150
sp+50: 00000000 20CDC3A4 20CD9CE0 20CD9CE0
sp+60: 20CD9CE0 20CD9CE0 00000007 20CD9CE0
sp+70: 00000000 20CDC354 20CD9CE0 20CD9CE0
sp+80: 20CD9CE0 20CD9CE0 20CD9CE0 20CD9CE0
sp+90: 20CD9CE0 20CD9CE0 20CD9CE0 20CD9CE0
sp+A0: 20CD9CE0 20CD9CE0 20CD9CE0 20CD9CE0
sp+B0: 20CD9CE0 20CD9CE0 20CD9CE0 20CD9CE0
sp+C0: 20CD9CE0 20CD9CE0 20CD9CE0 20CD9CE0
sp+D0: 20CD9CE0 20CD9CE0 20CD9CE0 20CD9CE0
sp+E0: 20CD9CE0 20CD9CE0 20CD9CE0 20CD9CE0
sp+F0: 20CD9CE0 20CD9CE0 20CD9CE0 20CD9CE0
Register content:
Status: 3400FC25 Cause: 00800000
AT: 22DA0000
V0: 00000000 V1: 00000003
A0: 28EC3C90 A1: 000000D2
A2: 00000001 A3: 2442B38C
T0: 2442B500 T1: 3FFFF070
T2: 00000001 T3: 00050000
T4: 00000000 T5: 00000089
T6: 00800000 T7: 00009053
S0: 28EC3C90 S1: 000000D2
S2: 28E518F0 S3: 000000D3
S4: 000001A4 S5: 243C6000
S6: 00000001 S7: 00000002
T8: 36B27D28 T9: 00000001
K0: A0000000 K1: A1907668
GP: 22D9FDE0 SP: 3FF720F8
S8: 21720000 RA: 20AC2A94
HIGH: 00000031 LOW: 04236E1F
BADVADDR: 00000000 ERR EPC: 20AEA1D0
CP0 Registers
contxt = fe800000 count = 67523fbe compare = ffffffff
config = 8040c083 xcntext = 00000000 ecc = 00000076
cacherr = 84000000 watchlo = fefbffe8 watchhi = c0fb0fe8
taglo = 00000000 taghi = 00000000 deradr0 = 00000000
deradr1 = 00000000
Extended Exception log:
Version 1. Saved on Aug 20 2008 17:26:54 ...
Stored 42 Registers. Current S/W displays 42.
satish_zanjurne
Level 4
Level 4
Hi can you attach the "show tech" output.
It will be easy to find the meaning of the above errors.
Be careful, while using "show tech" as it generaates a lot of output..
Giuseppe Larosa
Hello Uzziel,
see
http://www.cisco.com/en/US/docs/ios/12_2sx/system/messages/sm2sx05.html#wp1040226
MISTRAL Messages
This section contains Mistral ASIC (MISTRAL) messages.
MISTRAL-3
Error Message %MISTRAL-3-BAD_PAK: Possibly un-encapsulated packet passed to Mistral:
int [chars] type [int] stat [hex] flags [hex] size [dec] encsize [dec] offset [dec]
requeue_token [int] r1 [int] r2 [int] total detected [int]
Explanation A badly encapsulated packet from the process level was passed to the Mistral ASIC.
Recommended Action Copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://tools.cisco.com/ServiceRequestTool/create, or contact your Cisco technical support representative and provide the representative with the information you have gathered. Attach the following information to your case in nonzipped, plain-text (.txt) format: the output of the show logging and show tech-support commands and your pertinent troubleshooting logs.
Error Message %MISTRAL-3-NOEOBCBUF: No EOBC buffer available. Dropping the packet.
Explanation The Ethernet out-of-band channel pool of receive buffers for the Mistral ASIC has been exhausted. No additional input packets can be handled until some buffers are returned to the pool.
try to post the sh stack output on the output interpreter.
If this error happened multiple times you may need an HW replacement.
MISTRAL is the name of an ASIC I don't know if it is on a linecard or on the supervisor.
Hope to help
Giuseppe
Hi, im sending you the output of the show log command, i wish to know about the exceptions counters and why could it be increasing.
this exception caused the equipment reset.
Attached file.
thanks.
Hello Uzziel
here is the output of the output interpreter.
Is asking the sequence:
sh module
sh log
CATALYST STACK DECODE NOTIFICATIONS (if any)
ERROR: Stack content is present from 'show log' but additional information is
missing from 'show module'.
The required information to decode the stack content is available by using a combination
of commands based on the Catalyst platform.
For Catalyst 4000:
- 'show module'
- 'show crashdump 1'
For Catalyst 5000 and 6000:
- 'show module'
- 'show log'
TRY THIS: This output is from a Catalyst 5000 or 6000 and you need to submit the
output from both the 'show module' and the 'show log' commands (in that order).
Please include both command output in the same submission to receive a decode of
the stack trace.
Back to top
SHOW LOG (CatOS) NOTIFICATIONS (if any)
INFO: The counters found in the 'show log' output are totals since the last 'clear
log' command was entered. These statistics are kept even after reloading the switch.
Use the 'clear log' enable mode command to ensure that these counters are current.
For the ACTIVE NMP
WARNING: Power Supply 1 has failed 1 times.
Note: These numbers may be misleading and should be carefully interpreted.
TRY THIS: Capture the output of 'show system' and submit it to the Output Interpreter
for analysis. Submit 'show tech-support' output for a system wide analysis from
the Output Interpreter.
REFERENCE: For additional Hardware Troubleshooting information, please visit
the appropriate page:
Hardware Troubleshooting for Catalyst 4000/4912G/2980G/2948G Series Switches
Hardware Troubleshooting for Catalyst 5500/5000/2926G/2926 Series Switches
Troubleshooting Catalyst 6500/6000 Series Switches in Hybrid Mode
Troubleshooting Hardware and Common Issues on Catalyst 6000 Series Switches
Running Cisco IOS (Native)
WARNING: The log output indicates 1 exceptions.
This number tracks the number of exceptions in the program and the number of Non-Maskable
Interrupt (NMI) counters. It tracks error conditions that altered the normal
flow of the program. It also tracks changes in conditions that cause the microprocessor
to stop the current task and handle the situation through a different routine.
These exceptions are similar to interrupts. The NMI is a variant of an interrupt.
It is a high-priority interrupt that cannot be disabled by another interrupt
operation. Fatal exceptions (which are exceptions where packets cannot be forwarded),
are recorded on the NVRAM log.
TRY THIS: Reseat the Supervisor module and all the linecards. If there is a frequent
increase in the number of exceptions, open a service request with Cisco at
TAC Service Request Tool.
Hope to help
Giuseppe
