permit RIP without enabling it thru ASA 5510
Aug 25th, 2008
is it possible to permit RIP through a 5510, using 7.2(10)2, without enabling RIP?
Overall Rating: 3.5 (6 ratings)
Marwan ALshawi Mon, 08/25/2008 - 18:38
in ur case u need to run the ASA in transparant mode
in this case the ASA will work as a layer two device will not participat in any layer three addressing things and u can put it between two devices in the same ip addressing subnet
for example if u have PC >> ASA transparant mode>> router
the PC default gateway will be thw router
so if u have
Router with rip >>ASA transparnt mode>>> router with rip
those two routers can comunicate as in the same network as they connected to aswitch
however u need to permit the traffic through the ASA
just permit ip traffic for rip and multicasting for rip updates and thats it
have a look at the following link
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a008089f467.shtml
good luck
if helpful rate
Farrukh Haroon Mon, 08/25/2008 - 18:40
In transparent mode you can do this for sure. As in the 'Layer 2' mode of the firewall.
In the routed mode, you can make a GRE tunnel between the two devices and run inside it. You will then allow this GRE through the ASA.
Farrukh
ksvy_ksvy Mon, 08/25/2008 - 19:31
ok, works in transparent mode, and will need a GRE tunnel to go thru routed mode... routed mode is required for the site where the 5510 is going to
one more favor; need a white page for setting up a GRE tunnel for this purpose
thanks, kevin
Farrukh Haroon Tue, 08/26/2008 - 04:31
The link you sent is to allow L2TP or PPTP though firewall. It has no direct relation to this discussion. If you want to permit GRE then you can use a similar ACL as the link, as PPTP also uses GRE. But other than that, this link is not what you are looking for.
Farrukh
ksvy_ksvy Tue, 08/26/2008 - 04:36
right, but it's the only reference to a GRE ACL for a ASA that I could find.
I not so sure a GRE tunnel for IOS routers is what would work either.
thanks, Kevin
