NAM - ftp backup...showing following errors
Aug 25th, 2008
I am trying to take backup of daily reports from my NAM to ftp server.
I am receiving constant error :
42. 25 Aug 07:41:03 FTP report failed. cd Access failed 550 /C /Inetpub/ftproot/Aug-25-08 The filename, directory name, or volume label syntax is incorrect. (/C \Inetpub\ftproot/Aug-25-08)
43. 25 Aug 07:36:03 FTP report failed. cd Login failed 530 User hclcomnet cannot log in.
44. 25 Aug 07:31:04 FTP report failed. cd Access failed 550 /C /Inetpub/ftproot/Aug-25-08 The filename, directory name, or volume label syntax is incorrect. (/C \\\\Inetpub\\\\ftproot/Aug-25-08
Please help.
Regards.
SVA
Joe Clarke Mon, 08/25/2008 - 21:10
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
It looks like your NAM's FTP configuration is invalid. The user hclcomnet cannot log in to the FTP server, and the directory syntax isn't good. You need to correct these things under Admin > System > FTP Configuration, then make sure your scheduled report export is using the proper FTP entry.
