two routes summarise
Aug 25th, 2008
We are running OSPF routing protocol and we want to dvertise only the two summarize routes 10.8.0.0/16 and 10.4.0.0/16 on our perimeter devices(cisco routers) which are connected to our collabarative network.
Is it possible to advertise two sumarize router 10.8.0.0/16 and 10.4.0.0/16 ?
Istvan_Rabai Tue, 08/26/2008 - 18:51
  • Gold, 750 points or more
Hi Azmath,
Based on the scarce information I have from your post, I can ask you the following:
Why don't you advertise the summarized route of the 2 above: 10.0.0.0/12 ?
Cheers:
Istvan
Istvan_Rabai Tue, 08/26/2008 - 19:31
But finally, if you want, you can use the "area range" command multiple times to advertise the 2 summaries.
Cheers:
Istvan
