NAT on IPSec tunnel between 2x IOS routers (877)
Answered Question
Aug 25th, 2008
Hi All,
We have a customer with 2x 877 routers connected to the internet. These routers are configured with an IPSec tunnel (which works fine). The issue is the inbound static NAT translations causes problems with the tunnel - port 25 is mapped to the Inside address of the mail server. The existing config works fine for inbound mail, but prevents users from accessing the mailserver directly (using the private IP) on port 25.
Here's the NAT Config:
ip nat pool INET_POOL <publicIP> <publicIP> netmask 255.255.255.252
ip nat inside source route-map INET_NAT pool INET_POOL overload
ip nat inside source static tcp 10.10.0.8 25 <publicIP> 25 extendable
ip nat inside source static tcp 10.10.0.8 80 <publicIP> 80 extendable
ip nat inside source static tcp 10.10.0.8 443 <publicIP> 443 extendable
ip nat inside source static tcp 10.10.0.7 1433 <publicIP> 1433 extendable
ip nat inside source static tcp 10.10.0.7 3389 <publicIP> 3389 extendable
route-map INET_NAT permit 1
match ip address 101
access-list 101 deny ip 10.10.0.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 101 permit ip 10.10.0.0 0.0.0.255 any
On ASA's I would setup a NAT exemption, but how can I achieve the same thing in IOS?
Cheers,
Luke
Correct Answer by Farrukh Haroon about 8 years 4 months ago
Overall Rating: 5 (1 ratings)
Hello, my name is Nelson and I have the some problem.
I have a customer with a VPN working just fine. He can access the remote PCs (3389 port) via VPN without any problem. Now, they ask us to open 3389 to a particular outside IP (from Internet). The question is that when I configure the static pat for 3389 port, the customer loses the access via VPN to 3389 port of remote PC because of the static nat.
ip nat inside source static tcp 192.2.100.1 3389 3389 extendable
How can I open the 3389 to the external IP (from the Internet) and keep the access to remote sites of the customes ?
Any idea ?
Best regards,
Nelson
This is the configuration I have in one site:
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp keepalive 10
crypto isakmp peer address
set aggressive-mode password xxx
set aggressive-mode client-endpoint fqdn 110.110.iteuve.oni.pt
crypto ipsec transform-set iteuve esp-3des esp-md5-hmac
crypto ipsec df-bit clear
crypto map IPSECMAP 10 ipsec-isakmp
set peer
set transform-set iteuve
match address 111
interface Ethernet0
ip address 192.2.100.254 255.255.255.0
ip nat inside
ip tcp adjust-mss 1300
no cdp enable
hold-queue 100 out
interface BRI0
no ip address
shutdown
no cdp enable
interface ATM0
no ip address
atm vc-per-vp 64
no atm ilmi-keepalive
pvc 0/35
pppoe-client dial-pool-number 1
dsl operating-mode auto
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer remote-name redback
no cdp enable
ppp authentication pap chap callin
ppp pap sent-username [email protected] password xxx
ppp ipcp dns request
ppp ipcp wins request
crypto map IPSECMAP
ip nat inside source list 169 interface Dialer1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
no ip http secure-server
access-list 111 permit tcp 192.2.100.0 0.0.0.255 any eq pop3
access-list 111 permit tcp 192.2.100.0 0.0.0.255 any eq smtp
access-list 111 permit udp 192.2.100.0 0.0.0.255 any eq domain
access-list 111 permit tcp 192.2.100.0 0.0.0.255 any eq 123
access-list 111 permit ip 192.2.100.0 0.0.0.255 host
access-list 111 permit tcp 192.2.100.0 0.0.0.255 host eq www
access-list 111 permit tcp 192.2.100.0 0.0.0.255 host eq 8080
access-list 111 permit udp 192.2.100.0 0.0.0.255 host eq 8080
access-list 111 permit ip 192.2.100.0 0.0.0.255 192.2.0.0 0.0.255.255
access-list 169 permit tcp 192.2.100.0 0.0.0.255 any eq pop3
access-list 169 permit tcp 192.2.100.0 0.0.0.255 any eq smtp
access-list 169 deny ip 192.2.100.0 0.0.0.255 any
dialer-list 1 protocol ip permit
When I put the static nat line the customer can not remote access (3389 port) to the PC with IP 192.2.100.1 via VPN (starting the session from another site).
