1841 or 2821 or other Cisco modell hwic-3g-gsm+HWIC-AP-AG-E or HWIC-AP-G-E
bjosu
Hi all.
I want to build a portable accesspoint that uses hwic-3g-gsm and a HWIC AP card AG or G.
Or a model with build-in Wlan+3G.
But i cannot find information what models that supports 2 HWIC card at the same time.
Do i need a 3825 or can i use 1841 or 2821?
Giuseppe Larosa
Hello Bjorn,
a 1841 is enough:
Both slots on the Cisco 1841 router are HWIC slots and provide compatibility with WICs and multiflex trunk (VWICs) interface cards
(for data only).
http://www.cisco.com/en/US/prod/collateral/routers/ps5853/product_data_sheet0900aecd8016a59b.html
Hope to help
Giuseppe
Thank you for answer.
You can not use 2 Cisco HWIC-AP card at the same time.
But it may be possible to use 3G+AP card at the same time.
This limitation could be that you can not use 2 HWIC at the same time or just a limit so that you do not use 2 HWIC-AP at the same time.
Bjorn Sundin.
