track ip route
Aug 26th, 2008
hi,
I have a 4506 switch running 12.2-31.SGA7
and i use static routes instead of routing protocols.
How can i check the state on a static route?
I want to add backup routes with track but the IOS doesnt support the rtr command only track <1-500> ip route.
satish_zanjurne Tue, 08/26/2008 - 02:54
If you are going to add backup route also static one, then you can make the backup static route as floating by putting it's administrative distance higher..
...so you don't have to worry about tracking your primary static route!!!
HTH..
kon_salev Tue, 08/26/2008 - 03:13
I also have floating backup static routes but dont work because the switch cant understand that a route is "down". Is more than one hop awy.
