Change unity_install password in AD
Aug 26th, 2008
I'm wondering if I reset the password of unity_install in Active Directory when Unity is running in UM, that I'm able to log on onto Unity via the new unity_install password. Reason for this is that the customer has lost his password and need to be sure that after modifying the password that Unity is still working.
David
Jaime Valencia Tue, 08/26/2008 - 06:55
if you're asking if you can change it, the answer is yes. if you're following the guides that state which services run over which accounts NO service should be running with the unityinstall account
java
if this helps, please rate
