08-26-2008 02:47 AM - edited 02-21-2020 02:59 AM
Dear All,
I configured the NAC HA for one of our customer. The HA is working well.When i connected the pc to the un-trusted vlan i am getting the auth page where i could get only local DB not getting the AD provider in the drop-down.
How can i solve this issue.
swami
08-26-2008 05:07 AM
Hi Swami, I have a couple of questions
Have you created an authentication type for your Domain Controller(s) under the Auth Server Menu of the CAM?
Is the Clean Access Agent installed on the local PC?
Does this happen with both L2 and L3 connections?
Is this configuration IB or OOB?
08-28-2008 10:05 AM
you have two choice
1- use SSO AD with agent
2- configure LDAP to AD and then you will get LDAP auth and local DB
