wireless authenticaiton with ISA
Aug 26th, 2008
I have implemented a WISM on 6500, with WLAN defined for windows client using PEAP. Authenticaiton server is MS IAS server with SSL certificate installed.
Now the users are connecting and authenticated fine.
When the user disconnect and try to re-connect, it never ask for user credentials. It just connects. I want to disable this and want to enter user credentials each time user tries to connect.
How can I achieve this ?
Trending Topics - Security & Network
