IP addressing
Answered Question
Aug 26th, 2008
my n/w has /26 subnet, IP range is 10.36.27.64 to 10.36.27.127. Now i want to upgrade to /24 subnet, then IP range will be 27.0 to 27.255.
Can i use same default gateway i.e 27.127 for all hosts? as changing only subnet mask on all hosts & switch interface. Pls suggest
Ramesh
Correct Answer by Edison Ortiz about 8 years 5 months ago
Ramesh,
The gateway needs to be in the same subnet as the clients that is servicing.
If you decide to keep the subnet mask of /26, only the clients within the .64 to .127 range will be able to use .127 as the gateway.
If you decide to change the subnet mask to /24, clients within the .1 to .254 can use the .127 as the gateway.
HTH,
__
Edison.
Overall Rating: 4.5 (2 ratings)
keeleym@o2.ie Tue, 08/26/2008 - 04:45
Hi There
Yes, no problem. You can use any of the 254 available IP addresses on the subent as the default gateway.
Most networks I have come across appear to use either the first (.1) or last (.254) available IP address as the default gateway, but again this not a requirement but rather a standard the the Net Admins appear to adhere to.
Best Regards,
Michael.
nramesh25 Tue, 08/26/2008 - 05:04
Thanks for ur mail.
If i am not changing my subnet mask whether it will work or not? (Range 10.36.27.64 to 27.127)
Ramesh
Correct Answer
Edison Ortiz Tue, 08/26/2008 - 05:10
Ramesh,
HTH,
__
Edison.
