International Dial-Plan with CCM 5.1
Aug 26th, 2008
does anyone know how to know what route patterns are present in the cisco IDP.
I have a customer who wants to know which of cisco's IDP version has the new 075 numbers in them..
any ides?
dezoconnor Tue, 08/26/2008 - 07:10
I believe anything above 1-1-6 has the required 075 numbers. The last one we used was 1-1-7 and I think it was in there.
Ayodeji oladipo... Tue, 08/26/2008 - 08:03
thanks. I have checked 1-1-7 and the Route pattern in the IDP is 0+7[57-9]XX+XXXXXX.
So some patterns are missing for new mobile numbers eg 0750XXXXXXX
We will just add it manually
iptuser55 Tue, 08/26/2008 - 08:05
Be aware if you use Route Filters and you upgrade to 1-1-6. The upgrade will not work you need to remove the filters and upgrade and then implement the filters again . In pre 1-1-6 there are references to charge bands which do not appear in 1-1-6 and even if you do not use them for certain filters are still in the dial plan so the upgrade will fail
