VPN Concentractor SSL Certificate Expired - Urgent Help
Aug 26th, 2008
We have VPN concentractor 3030. Whe I log on via web its says that SSL certificate has expires and I cannot login to generate new certificate.
I even tried login via consol but it won't allow the connection.
What can I do.
Farrukh Haroon Tue, 08/26/2008 - 06:16
  • Red, 2250 points or more
What has the certificate gotta do with the console access?
Farrukh
patel.nishit Tue, 08/26/2008 - 06:52
When logging via web GUI SSL Certificate is failing and won't allow access.
But I can't enve login via Console.
Farrukh Haroon Tue, 08/26/2008 - 07:08
What is the error? (On the console)?
Farrukh
patel.nishit Tue, 08/26/2008 - 07:13
We don't even see the prompt. The cable and connector has been checked on other device and it works fine.
Is their any work around resolving the SSL certification issue as it has expired.
Farrukh Haroon Tue, 08/26/2008 - 12:25
The CONSOLE has nothing to do with the certificate. No matter what you should see the console prompt. If you cannot, make sure you are using a STRAIGHT THROUGH DB9 cable.
NOTE: This cable is different from the one used by PIX 520 and IDS boxes.
Farrukh
Farrukh Haroon Thu, 08/28/2008 - 00:20
As a workaround try to set back the date on your system to a data before the certificate expired. Then access the GUI.
However as I said before, this has NOTHING to do with the console, it will still work.
Farrukh
